BT.com
Wishlist
AOC Lenovo AOC Pro-line M2060PWQ LED Monitor 19.5" 1920 x 1080
AOC Lenovo AOC Pro-line M2060PWQ...
£108.98
16 in stock
£108.98
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
AOC Pro-line M2060PWQ - LED monitor - 19.53"
LED-backlit LCD monitor - 19.53"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
47.76 cm x 17.95 cm x 35.83 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, TUV Bauart, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
19.53"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology
47.76 cm x 17.95 cm x 35.83 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort
Mechanical
Tilt Angle
-5/+22
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Limited warranty - 3 years
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£9.16
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£46.21
£11.96
£23.40
£20.80
£15.94
Scroll to top
