BT.com
Wishlist
AOC i2757fm 27" 1920 x 1080 5MS 2xHDMI VGA Speakers LED Monitor
Delivery
Standard Due date unavailable
This Full HD monitor blows the contents of your Android devices up to an impressive size: With the innovative MHL™ interface (Mobile High-Definition Link) high-resolution photos, videos and games can be displayed directly from a smartphone or tablet PC on the huge 68.6 cm (27?) screen. A practical side effect: the mobile gadgets get charged at the same time. The LED model utilises the high-quality IPS display technology, which, besides providing a strong contrast und a brightness of 250 cd/m², stands for exceptionally good colour fidelity and viewing angle stability. A big stage for your photos and videos!
Product Details
  • Inputs: D-SUB, HDMI
  • 1920 x 1080 maximum resolution
  • Special Features: audio out, DCR, Eco Mode, e-Saver, i-Menu, MHL, screen+, Kensington Security Lock, Headphone out
  • 250 cd/m²
  • 5ms GtG
AOC myPlay I2757FM - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
32 W
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Black, silver
62.2 cm x 13 cm x 44.9 cm
5.7 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, BSMI, DDC-2B, CCC, FCC, DDC/CI, ISO 9241-307, CEL, cCSAus, EPA
3 years warranty
Display Type
Energy Class
Class A
46 kWh
32 W
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, input select
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP
Black, silver
5.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , 2 x HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
40 Watt
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
No
Limited warranty - 3 years
Accessories
£7.41
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.13
£40.20
£54.46
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* good
Reviewed by steve on 31/08/2013
A good quality monitor with a decent picture, A little difficult to set up as the manual just says what the settimgs are called and doesn't tell you what they do.
Also the on/off button is a bit fiddley, you need to push it fairly hard to turn it on/off which means you need to grab the side/underside with you fingers and push the button with your thumb. otherwise the force needed to push the button would be enough to move the whole monitor back.
other than that no real problems.
Scroll to top
