BT.com
Wishlist
AOC I2476VWM 23.6" 1920x1080 5ms VGA HDMI IPS LED Monitor
AOC I2476VWM 23.6" 1920x1080 5ms...
£116.98
£116.98
Add to wishlist
Delivery
Standard Due date unavailable
The AOC i2476Vwm display will impress the most demanding users. This 23.6-inch ADS-IPS screen has Full HD 1920 x 1080 resolution for brilliantly detailed movies and images with wide 178 degree viewing. Gamers will appreciated the fast 5ms response time that reduces ghosting and blur, and 50M:1 dynamic contrast offers rich, true blacks. The headphone jack and 2 watt speakers deliver crystal-clear sound for music or video calls with friends. Hook up your computer, laptop or game console with the built-in VGA and HDMI connectors. The stylish black finish and ultra-slim profile make it an elegant accent to your office or living room, while the VESA mount lets you hang it on the wall. The i2476Vwm display is the ideal choice for anyone who wants the ultimate image quality and performance at an attractive price.
AOC Value I2476VWM - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
55.81 cm x 18.34 cm x 42.78 cm
3.84 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, GOST, RoHS, ISO 9241-307, TCO '06, cTUVus, TUV Bauart, EuP
3 years warranty
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
23.6"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
3.84 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-4/+21.5
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable , 1 x power cable , 1 x VGA cable
Power Supply
Internal
26 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
ENERGY STAR Certified
Limited warranty - 3 years
Other bundles
AOC I2476VWM 23.6
AOC I2476VWM 23.6" 1920x1080 5ms VGA HDMI IPS LED...
£116.98
Wireless keyboard and mouse set
£166.97
AOC I2476VWM 23.6
£116.98
Keep your electronic devices protected
£136.97
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
