BT.com
Wishlist
AOC I2360PHU 23" LED IPS 1920x1080 VGA DVI HDMI USB Height Adjustable LED Monitor
AOC I2360PHU 23" LED IPS 1920x1080...
£166.99
£166.99
Add to wishlist
Delivery
Standard 1-3 working days
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC Professional i2360Phu - LED monitor - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080 at 60 Hz
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Speakers
Integrated
Display Position Adjustments
54.85 cm x 24.45 cm x 37.52 cm
5.65 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, FCC, RoHS, ISO 9241-307, TCO '05, EuP, cCSAus
3 years warranty
Display Type
Energy Class
Class B
30 kWh
21 W
Diagonal Size
23"
Viewable Size
23"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
146 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, i-Menu, e-Saver technology
5.65 kg
Audio
Speakers - integrated
DVI-D , HDMI (HDCP) , VGA (HD-15) , 4 x USB , Headphones
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
AC 90 - 240 V (50/60 Hz)
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Gorgeous Monitor
Reviewed by Sean on 26/04/2013
I spent ages looking for a new monitor. I wanted 23", IPS, Height adjust and HDMI. This monitor ticked every box and many more besides. It's lovely, I can't fault any aspect of it. The clearest, crispest display I've ever had - it's the first IPS screen I've seen. Being tall, I've always had neck-ache from a conventional monitor. Now I can have it up in the air, and look horizontally. It's far healthier, in fact if I wasn't self-employed I'd have demanded one on health and safety grounds. I've had a few Dell screens in the past. This is every bit as robust, but much more elegant looking. I was concerned that I thought of AOC as an economy brand - there are complaints of some of their lesser models being flimsy or wobbly. I had nothing to worry about - it's rock-solid and very well made. It includes power, VGA, DVI, USB and 3.5mm audio cables. No HDMI cable, so don't forget to order one if you need it. I looked at Philips, Dell and Iiyama among others before deciding.
Scroll to top
