Click to visit BT.com
BT.com
Wishlist
AOC e905Swdak 18.5" 1366x768 5ms VGA DVI Glossy Black Monitor with Speakers
Quicklinx: 8K2NWS00
Mfr#: E950SWDAK
This model is characterized by the display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
AOC Value e950Swdak - LCD monitor - 18.5"
LCD monitor - 18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
44.435 cm x 17.5 cm x 34.2 cm
2.63 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, EuP
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Viewable Size
18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Eco-Mode, e-Saver technology
2.63 kg
Audio
Speakers
VGA , DVI-D
Mechanical
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
AC 90 - 240 V ( 50/60 Hz )
12 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Screen+, I-Menu
Limited warranty - 3 years
8K2N C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.21
8K2N C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.66
8K2N C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £15.15
8K2N C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £9.88
8K2N C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £9.49
8K2N C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £9.30
8K2N C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £48.08
8K2N C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.30
8K2N C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £64.80
