BT.com
Wishlist
AOC E2450SWHK 23.6" 1920 x 1080 2MS VGA DVI HDMI LED Monitor
Delivery
Standard Due date unavailable
This model is characterized by the latest display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base. Thanks to numerous features it is recommended for both office and home.
AOC Value e2450Swhk - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
56.922 cm x 20.5 cm x 41.395 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
GOST, RoHS, TCO Displays 5.0, EuP
3 years warranty
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23.6"
Viewable Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Power off timer, HDCP, Eco-Mode, Dynamic Color Boost, i-Menu, e-Saver technology, Screen+
Glossy black
56.922 cm x 20.5 cm x 41.395 cm - with stand
5.3 kg
Audio
Speakers
DVI-D , VGA , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable , 1 x audio cable
Power Supply
Internal
19 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 56.922 cm - depth: 20.5 cm - height: 41.395 cm - weight: 5.3 kg , Without stand - weight: 4.45 kg
Limited warranty - 3 years
Scroll to top
