BT.com
Wishlist
AOC e2450Swdak 23.6" 1920 x 1080 5MS VGA DVI Speakers LED Monitor
Free delivery
Delivery
Standard Due date unavailable
This model is characterized by the display technology with LED backlights, a top performance and a timelessly classic design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fast movie sequences fluently and razor-sharp. At its slim region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
AOC Value e2450Swdak - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
56.922 cm x 20.5 cm x 41.395 cm
4.45 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, TCO Displays 5.0, EuP
3 years warranty
Display Type
Diagonal Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode
Glossy black
4.45 kg
Audio
Speakers - integrated
VGA , DVI-D , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
K-lock security slot
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
35 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Screen+, I-Menu, e-Saver
Microsoft Windows 7
Limited warranty - 3 years
Scroll to top
