BT.com
Wishlist
AOC 23" LED VGA HDMI With Speakers
Delivery
Standard 1-3 working days
The 23" Full HD model sets a new milestone in IPS display technology. The fantastic design offers extensive connectivity options, such as D-Sub, two HDMI connectors and a DisplayPort. Its practical MHL interface allows you to hook up your Android mobile devices directly to the monitor. These monitors are known for vivid colours as well as high viewing angle stability. The display comes with a 250 cd/m² brightness, a typical contrast of 1000:1 (dynamic contrast: 50,000,000:1) and a 5 milliseconds response time for your ultimate viewing experience.
AOC Value i2369Vm - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
53.14 cm x 20.4 cm x 39.8 cm
4.89 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, TCO '06, TUV Bauart, ISO 9024-307, EuP, NRTL
3 years warranty
Display Type
Energy Class
Class B
29 kWh
20 W
Diagonal Size
23"
Viewable Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
4.89 kg
Audio
Speakers
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
Power Supply
Internal
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
