BT.com
Wishlist
Antec VSK 3000B-U3/U2 Tower mATX - No Power Supply - USB/Audio
Antec VSK 3000B-U3/U2 Tower mATX -...
£22.32
7 in stock
£22.32
Add to wishlist
Delivery
Standard 3-5 working days
For system builders old and new, the VSK3000E is the simple, reliable and cost-effective solution for your home or office. The VSK3000E is designed with durable, galvanized steel construction and is Intel Thermally Advantaged Chassis (TAC) 2.0 compliant to ensure stability and excellent cooling for all your system builds. With support for motherboards up to microATX, the case also supports 12.5" graphics cards. In addition, the stylish front panel is equipped with two USB 3.0 ports, Audio In/Out jacks and other computing essentials. If you're looking for a simple, reliable case that won't break For system builders old and new, the VSK3000E is the simple, reliable and cost-effective solution for your home or office. The VSK3000E is designed with durable, galvanized steel construction and is Intel Thermally Advantaged Chassis (TAC) 2.0 compliant to ensure stability and excellent cooling for all your system builds. With support for motherboards up to microATX, the case also supports 12.5" graphics cards. In addition, the stylish front panel is equipped with two USB 3.0 ports, Audio In/Out jacks and other computing essentials. If you're looking for a simple, reliable case that won't break the bank, the VSK3000E fits the bill.
Antec VSK 3000B-U3/U2 - tower - micro ATX
System cabinet
Tower
I/O Connectors
1 x USB 2.0 , 1 x USB 3.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
TAC2.0 (Thermally advantaged chassis version 2.0), steel body
No power supply
17.3 cm x 39.3 cm x 36.5 cm
4.1 kg
2 years warranty
Tower
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
Internal Bays Qty
3
Front Accessible Bays Qty
3
Cooling System
Rear: 92 mm fan x 1 / exhaust , Front: 92 mm fan mount x 1 / intake
Video Card Max Length
318 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 2 (total) / 2 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
4
1 x USB 2.0 , 1 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
RoHS
No power supply
17.3 cm
39.3 cm
36.5 cm
4.1 kg
Antec VSK 3000B-U3/U2 Tower mATX - No Power Supply -...
£22.32
Save on this ideal PC Build kit!
Save £16.94
£47.70
Accessories
C2G 4 port USB 3.0 SuperSpeed Hub
Quicklinx: 7CBW | In Stock
£72.94
Scroll to top
