BT.com
Wishlist
Antec VP600P - Power supply ( internal ) - AC 230 V - 600 Watt
Antec VP600P - Power supply (...
£53.88
7 in stock
£53.88
Add to wishlist
Delivery
Standard 3-5 working days
The VP600P is crafted for quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkly lights or glittery paint jobs - a 120 mm fan for effective and quiet cooling, dual +12 V rails for amazingly stable power and heavy-duty protection circuitry for peace of mind, no matter how demanding your system. All the features, none of the waste: for builders that are strictly business, the VP600P is strictly power.
Antec VP600P - power supply - 600 Watt
Power supply - internal
1.6 kg
United Kingdom
Input Voltage
AC 230 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
2 years warranty
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50 - 60 Hz
Max Electric Current
4.5 A
Power Capacity
600 Watt
Output Current
+5V - 20 A , +3.3V - 20 A , +12V1 - 30 A , +12V2 - 30 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
88%
Cooling System
120 mm fan
Thermal monitoring, short-circuit protection
TUV, CB, CCC, RoHS, GOST-R, S Mark, Energy-Related Products (ErP) Lot 6, RCM
15 cm
14 cm
8.6 cm
1.6 kg
Scroll to top
