BT.com
Wishlist
Antec Truequiet 120mm 2 Way Switch Blue Led Fan
Delivery
Standard Due date unavailable
Antec's TrueQuiet fans bring proven cooling and Quiet Computing to your system. Constructed for versatility, TrueQuiet fans include a convenient 2-speed switch that allows you to easily choose either silent or maximum RPM cooling. Because a functional computer relies on more than just cooling, TrueQuiet is equipped with silicone grommets and a uniquely-designed fan blade to reduce turbulence, vibration and noise for overall quiet operation. Upgrade your fans and add optimal cooling and functionality to your PC with TrueQuiet.
Antec TrueQuiet 120 LED - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600/1000 rpm
Air Flow
21.1/46.3 cmf
Noise Level
8.9/19.9 dBA
Power Connector
3-pin plug, 4 pin Molex connector
12 cm x 12 cm x 2.5 cm
138.9 g
Blue LED lighting, adjustable speed
2 years warranty
Case fan
12 cm
12 cm
2.5 cm
138.9 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600/1000 rpm
Air Flow
21.1/46.3 cmf
Noise Level
8.9/19.9 dBA
Power Connector
Power Consumption
0.7-1.4 W
RoHS
2 years warranty
Service & Support Details
Scroll to top
