BT.com
Wishlist
Antec TrueQuiet 120
Antec TrueQuiet 120
£8.96
Antec TrueQuiet 120
Antec TrueQuiet 120
27 in stock
£8.96
Add to wishlist
Delivery
Standard 3-5 working days
Antec's TrueQuiet fans bring proven cooling and Quiet Computing to your system. Constructed for versatility, TrueQuiet fans include a convenient 2-speed switch that allows you to easily choose either silent or maximum RPM cooling. Because a functional computer relies on more than just cooling, TrueQuiet is equipped with silicone grommets and a uniquely-designed fan blade to reduce turbulence, vibration and noise for overall quiet operation. Upgrade your fans and add optimal cooling and functionality to your PC with TrueQuiet.
Antec TrueQuiet 120 - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600/1000 rpm
Air Flow
21.5/35.8 cfm
Noise Level
8.9/19.9 dBA
Power Connector
3-pin plug, 4 pin Molex connector
12 cm x 12 cm x 2.5 cm
139 g
Fan speed monitoring
2 years warranty
Case fan
12 cm
12 cm
2.5 cm
139 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600/1000 rpm
Air Flow
21.5/35.8 cfm
Noise Level
8.9/19.9 dBA
Power Connector
RoHS
2 years warranty
Antec TrueQuiet 120
Antec TrueQuiet 120
£8.96
Save on this ideal PC Build kit!
Save £10.63
£28.13
Scroll to top
