BT.com
Wishlist
Antec Sonata Proto Quiet Mid Tower Case
Delivery
Standard Due date unavailable
Get all the features and performance of the renowned Sonata line of enclosures with the Sonata Proto without breaking the bank. With 9 drive bays, 7 expansion slots, an intake air filter, the Sonata Proto offers a plethora of features and has all the quiet performance that the Sonata line is famous for. Along with its convenient front mounted USB 2.0 and HD audio connectors, the Sonata Proto is the ideal combination of silence, efficiency and affordability.
Antec Sonata Proto - mid tower - ATX
System cabinet
Mid tower
Europe
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
ATX, microATX, Mini-ITX
No power supply
20.6 cm x 46.2 cm x 42.4 cm
7.5 kg
Mid tower
Max Mainboard Size
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
5
Fans
Front : 1 x 12 cm - ( 0 installed) , Rear : 1 x 12 cm - ( 1 installed)
Europe
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 3.5" x 1/3H , 4 (total) / 4 (free) x internal - 3.5" x 1/3H
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
Max Supported Qty
1
20.6 cm
46.2 cm
42.4 cm
7.5 kg
Accessories
C2G 4 port USB 3.0 SuperSpeed Hub
Quicklinx: 7CBW | In Stock
£68.11
C2G 2m USB 3.0 A Male to Micro B Male Cable
Quicklinx: 7GNS | In Stock
£6.75
Resources
The following resources are available for the Antec Sonata Proto Quiet Mid Tower Case
  • Documentation
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Ideal for mid range builds
Reviewed by Arthur Suggs on 10/06/2013
Bought several of these over the years and find they are nicely laid out box for "standard" home pcs. You get plenty of space for the internal 5.25 drives on quick release trays that have rubber grommets to reduce vibration. The top front will take up to 3 external full width devices eg DVD player, SATA drive dock plus the 3.5" bay gives a slot for say, a card reader. Note that the SSD mount is actually 4 raised holes in the bottom of the case and you will have to watch the cable fixing to the drive as it comes close to the side panel and puts a severe angle in the cable. There are 4 mount holes right behind the drive stack that can take another 12cm fan, and I find that a useful addition. Note that the spec from BT still shows the front USB ports as being USB 2, all the Sonata cases I've used in the past 12 months are in fact USB 3.0 with the composite plug/lead to match. Also, watch the length of your gfx card if you're thinking of a gaming rig.
Scroll to top
