BT.com
Wishlist
Antec S10 Case - Signature Series Tower Case
Delivery
Standard Due date unavailable
The full tower S10 is the flagship case of the Signature series by Antec, a family of chassis characterized by a patent pending internal architecture featuring an innovative Central Air Intake System and easy expandability with a striking, yet refined, exterior design. The exclusive three chamber design separates the enclosure into three thermal zones, providing clear airflow paths and efficient cooling to all of your components quietly. Seven pre-installed fans plus one optional fan mount combine with support for top, center, and rear radiators to showcase the ample cooling options available in the S10. Ten PCI-E slots and fourteen (6 HDD, 8 SSD) tool-less drive bays make building a high-performance system a simple process. Finished with a smooth front bezel and opposing brushed aluminum doors, the S10 provides performance, security, and style for any computer system.
Antec Signature Series S10 - full tower - extended ATX
System cabinet
Full tower
Black with brushed aluminum doors
I/O Connectors
4 x USB 3.0 , 1 x headphones/speakers , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Supports 120 mm radiator in rear, supports 240/280 mm radiator in top, supports 240/280/360 mm radiator in centre
No power supply
23 cm x 59 cm x 60.2 cm
20.42 kg
3 years warranty
Full tower
Max Mainboard Size
Extended ATX
Internal Bays Qty
14
Cooling System
Top: 140 mm fan x 2 / exhaust , 120 mm fan x 3 / intake , Rear: 120 mm fan x 1 / exhaust , 120 mm fan x 1 / exhaust , 120 mm fan mount x 1 / intake
CPU Cooler Max Height
165 mm
Video Card Max Length
343 mm
Expansion Bays
6 (total) / 6 (free) x internal - 3.5" , 8 (total) / 8 (free) x internal - 2.5"
Expansion Slots
10
4 x USB 3.0 , 1 x headphones/speakers - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
23 cm
59 cm
60.2 cm
20.42 kg
Limited warranty - 3 years
Scroll to top
