BT.com
Wishlist
Antec PSU/Basiq Power 350W ATX 12v
Delivery
Standard Due date unavailable
Building on a budget doesn't mean you have to trust your components to an un-reliable no-name brand. That's why Antec took its years of experience and knowledge in building world-class power supplies and made Basiq. The workhorse of the Antec family, Basiq is built with solid quality you have come to expect from Antec products at an unbeatable price. Basiq does the job simply, efficiently and reliably, making Basiq a solid power supply built to satisfy the demands on the entry-level power user or the budget minded system builder.
Antec Basiq BP350P-GB - power supply - 350 Watt
Power supply - Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.01
2.3 kg
United Kingdom
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
350 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
14.9 cm x 15.8 cm x 8.5 cm
2 years warranty
ATX12V 2.01
United Kingdom
Input Voltage
AC 115/230 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
350 Watt
MTBF
80,000 hours
Over voltage protection, overpower protection
FCC Class B certified, UL, TUV, cUL, CB, RoHS
Limited warranty - parts and labour - 2 years
50 °C
14.9 cm
15.8 cm
8.5 cm
2.3 kg
Scroll to top
