BT.com
Wishlist
Antec PRO 80mm Fan
Antec PRO 80mm Fan...
£5.02
Antec PRO 80mm Fan
Antec PRO 80mm Fan
25 in stock
£5.02
Add to wishlist
Delivery
Standard 3-5 working days
Case fans help protect your whole computer investment by providing case cooling to reduce component-killing heat buildup, thus increasing the longevity of components.
Antec PRO DBB - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
One sleeve & two ball bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
3-pin plug, 4 pin Molex connector
8 cm x 8 cm x 2.54 cm
70 g
Fan speed monitoring
Case fan
8 cm
8 cm
2.54 cm
70 g
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
RoHS
Sound Emission
30 dBA
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Very Disappointed
Reviewed by Chris on 11/10/2007
These fans are VERY loud, i have 2 other LED 80mm fans that cost about £1.30 each or something and they are quieter than these Antec ones. In fact i have two 50p (yes 50 PENCE) black generic 80mm fans that i got the Antec ones to replace and even they are quieter than these things. I am really quite annoyed i paid nearly £7 for these two fans and i have to use my Zalman FanMate to run them at half speed (11R00PM or thereabouts), i had to jerryrig the two fan connectors to do it, but it seems to work fairly well, but now i don't have anything to control my Zalman 9500 (except Q Fan which sucks). Bottom line, VERY loud and NOT good value.
Scroll to top
