BT.com
Wishlist
Antec P280 Performance Series PC Tower Case
Antec P280 Performance Series PC...
£113.89
£113.89
Add to wishlist
Delivery
Standard 1-3 working days
Sophisticated and cutting-edge, the P280 emphasizes the ease of use, quiet technology and unparalleled performance characteristic of Antec's Performance One series. This advanced enclosure comes equipped with features that will maximize your PC experience, from Quiet Computing panels and HDD drive bays, to grommet-lined cable routing holes with ample space behind the motherboard tray. And with convenient tool-less optical drive bays, easy-access front and bottom PSU intake air filters, two front panel USB 3.0 ports and an affordable price, you get an elite enclosure that will last you for builds to come.
  • 9 expansion slots and up to XL-ATX motherboards
  • 2 front panel USB 3.0 ports
  • Advanced cooling system: includes 3 fans and 4 additional fan mounts
  • Dual-layer design: 0.8 mm steel / polycarbonate side panels deaden noise
  • 6 quiet 3.5" / 2.5" drive bays utilize trays with preinstalled silicone grommets
  • 120 mm internal intake fans (optional)
  • Triple-layer (aluminum, plastic, foam) front bezel with double-hinged door: opens up to 270°
  • Grommet-lined cable routing holes with 30 mm of space behind the motherboard tray
  • 3 tool-less 5.25" drive bays
  • Fan power hub: 4 x 3-pin fan connector on a single Molex
  • PSU intake & front air filters
  • Model P280
  • Case Type Super Mid Tower
  • Color(s) Black with gunmetal anodized aluminum front door
  • Cooling System - 2 x 120 mm top TwoCool™ exhaust fans: 1 x 120 mm rear TwoCool™ exhaust fan / 2 x 120 mm internal intake fans (optional) / 2 x 120 mm front intake fans (optional) / Fan power hub allows you to connect four 3-pin fans to a single Molex for improved cable management
  • Drive Bays - 3 x 5.25" tool-less drive bays: 2 x 2.5" drive bays (dedicated) / 6 x 3.5" / 2.5" drive trays
  • Front Ports 2 x USB 3.0 with internal motherboard connector / 2 x USB 2.0 / Audio In/Out
  • Expansion Slots / video card size: 9 expansion slots / Maximum video card size: 13" / 330 mm
  • Maximum CPU Cooler Height 6.7" / 170 mm
  • PSU No power supply included
  • Motherboard Support XL-ATX [13.6" x 10.3" (345 mm x 262 mm)], Standard ATX, microATX, Mini-ITX
  • CPU Cutout Enlarged CPU cutout
  • Cable Management 30 mm of cable routing space behind motherboard tray
  • Side panel features None
  • Unit Dimensions- 526 mm (H) x 231 mm (W) x 562 mm (D) / 20.7" (H) x 9.1" (W) x 22.1" (D)
  • Net Weight: 22.3 lbs / 10.2 kg
Antec Performance One P280 - tower - XL-ATX
System cabinet
Tower
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 2 x audio
Supported Motherboards
XL-ATX
System Cabinet Features
Screwless drive bays, air filter, front panel door, bottom mounted PSU holder
No power supply
23.1 cm x 56.2 cm x 52.6 cm
10.2 kg
3 years warranty
Tower
Max Mainboard Size
XL-ATX
XL-ATX
Cooling System
Top: 120 mm fan x 2 / exhaust , Rear: 120 mm fan x 1 / exhaust , Internal: 120 mm fan mount x 2 / intake , Front: 120 mm fan mount x 2 / intake
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 2 (total) / 2 (free) 2.5" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
9 x Expansion Slot
RoHS
No power supply
23.1 cm
56.2 cm
52.6 cm
10.2 kg
Limited warranty - 3 years
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.75
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.32
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.09
£14.71
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.29
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.30
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£31.83
£50.76
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Slightly underwhelmed
Reviewed by cdstealer on 18/11/2015
I purchased this case as it met all my requirements and several online reviewers also confirmed what I was after. The case itself it great to build with. Lot's of room and reasonably high quality build as you'd expect from Antec. However, the front ports are not up to the job. The front audio ports became faulty and unusable after 3 uses and the USB ports seem to have too much play, so nudging the cable could result in the external device becoming disconnected. I have requested a replacement front port assembly from Antec, however, instead of just shipping the part, they requested I return the entire case to BT! I would have given this 5* if it wasn't for the low quality front ports and poor customer support from Antec :(
3* Faulty
Reviewed by Iang on 14/12/2015
Case good except for case fan that didn't work. Antec most unhelpful and required fan to be returned to Rotterdam at buyers expense for testing and possible replacement.
This for a £5 fan!
Not recommended.
Scroll to top
