BT.com
Wishlist
Antec One Gaming Case Mid Tower ATX
Antec One Gaming Case Mid Tower...
£44.59
12 in stock
£44.59
Add to wishlist
Delivery
Standard 3-5 working days
For builders and seasonal system integrators alike, everyone will find something to like in Antec's One. This enclosure is stocked with features any builder will value at an attractive price - ample cooling, USB 3.0, tool-less 5.25" and 3.5" drive bays and bottom-mounted PSU intake with air filter - so that you can put your PC together with ease and get to the fun stuff. If you're looking for high quality PC essentials at an affordable cost, then this enclosure is the One for you.
  • Front I/O ports: 2 x USB 3.0 with included USB 2.0 adapter / Audio In/Out
  • Tool-less 3.5"e; drive bays
  • Maximum graphics card length: 10.5"e; (266 mm)
  • 1 x 120 mm rear exhaust fan
  • 7 expansion slots
  • Tool-less 5.25"e; drive bays
  • Maximum size CPU cutout
  • 1 x 120 mm top exhaust fan
Antec One - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x audio line-out/headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Air filter, water cooling holes
No power supply
Specification Compliance
ATX
20.8 cm x 48.8 cm x 43.8 cm
4.9 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
7
Front Accessible Bays Qty
3
Cooling System
Top: 120 mm fan x 1 / exhaust , Rear: 120 mm fan x 1 / exhaust , Side: 120 mm fan mount x 1 / intake , Front: 120 mm fan mount x 1 / intake , Bottom: 120 mm fan mount x 1 / 1 x 140 mm fan supported
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 5 (total) / 5 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack
USB 2.0 adapter
No power supply
Max Supported Qty
1
20.8 cm
48.8 cm
43.8 cm
4.9 kg
£44.59
Save on this ideal PC Build kit!
Save £8.40
£63.81
Accessories
C2G 2m USB 3.0 A Male to Micro B Male Cable
Quicklinx: 7GNS | In Stock
£6.96
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 7YWQ 036319
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£25.16
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
