Click to visit BT.com
BT.com
Wishlist
Antec One Gaming Case Mid Tower ATX
Quicklinx: 7YWQWS00
Mfr#: 0-761345-15970-8
Case Form Factor: Mid tower
Motherboard Form Factor: ATX
Power Supply: [N/A]
Colour: Black
Standard delivery Delivered within 3-5 working days
24 in stock
£44.59
For builders and seasonal system integrators alike, everyone will find something to like in Antec's One. This enclosure is stocked with features any builder will value at an attractive price - ample cooling, USB 3.0, tool-less 5.25" and 3.5" drive bays and bottom-mounted PSU intake with air filter - so that you can put your PC together with ease and get to the fun stuff. If you're looking for high quality PC essentials at an affordable cost, then this enclosure is the One for you.
  • Front I/O ports: 2 x USB 3.0 with included USB 2.0 adapter / Audio In/Out
  • Tool-less 3.5"e; drive bays
  • Maximum graphics card length: 10.5"e; (266 mm)
  • 1 x 120 mm rear exhaust fan
  • 7 expansion slots
  • Tool-less 5.25"e; drive bays
  • Maximum size CPU cutout
  • 1 x 120 mm top exhaust fan
Antec One - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x audio line-out/headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Air filter, water cooling holes
No power supply
Specification Compliance
ATX
20.8 cm x 48.8 cm x 43.8 cm
4.9 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
7
Front Accessible Bays Qty
3
Cooling System
Top : 120 mm fan x 1 / exhaust , Rear : 120 mm fan x 1 / exhaust , Side : 120 mm fan mount x 1 / intake , Front : 120 mm fan mount x 1 / intake , Bottom : 120 mm fan mount x 1 / 1 x 140 mm fan supported
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 5 (total) / 5 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack
USB 2.0 adapter
No power supply
Max Supported Qty
1
20.8 cm
48.8 cm
43.8 cm
4.9 kg
Antec One Gaming Case Mid Tower ATX Bundle deal on Antec One Gaming Case Mid Tower ATX
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£64.12
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£48.68
saving £1.39
7YWQ C2G 4 port USB 3.0 SuperSpeed Hub In Stock £73.00
7YWQ C2G 2m USB 3.0 A Male to Micro B Male Cable In Stock £7.09
7YWQ C2G 3m USB 3.0 A Male to Micro B Male Cable In Stock £4.56
Power Supply: [N/A]
Colour: Black
Brand: Antec
Price Range Inc VAT: 0 - 50
