BT.com
Wishlist
Antec Mounting Kit For Isk 110 Vesa
Delivery
Standard Due date unavailable
Going small shouldn't mean sacrificing form or function. The ISK 110 VESA is crafted for small, efficient builds without compromises. Just 78 mm wide and mounted on a stable clip-on base or included VESA mount, it fits two 2.5" drive bays - perfect for internal SSDs. Perforated mesh construction and space for a low-profile CPU cooler provide an ample amount of quiet cooling capability. Ideal for corporate builds, kiosks and digital signage, the ISK 110 VESA is a miniscule case solution with massive features.
Antec ISK110 VESA - desktop slimline - mini ITX
System cabinet
Desktop slimline
Black, silver
English
I/O Connectors
4 x USB 2.0 , 1 x headphones , 1 x microphone
Supported Motherboards
Mini-ITX
System Cabinet Features
VESA mounting interface
Power adapter 90 Watt
AC 120/230 V
8.5 cm x 21.2 cm x 22.6 cm
1.3 kg
Desktop slimline
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Black, silver
English
Expansion Bays
2 (total) / 2 (free) x internal - 2.5"
4 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
AC 120/230 V
Power Provided
90 Watt
8.5 cm
21.2 cm
22.6 cm
1.3 kg
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
