BT.com
Wishlist
Antec Minuet 350 Piano Black Slimline PC Case
Antec Minuet 350 Piano Black...
£92.30
Elegant Mini-Desktop Case!
£92.30
Add to wishlist
Delivery
Standard Due date unavailable
This elegant mini-desktop boasts impressive performance and a remarkably svelte profile, perfect for system builders looking for a smaller chassis. Its slender footprint and included bracket allow it to fit vertically or horizontally into the tightest spaces. With a reliable high efficiency 80PLUS certified 350 watt power supply and front USB, eSATA and audio ports, the Minuet 350 delivers the ideal blend of performance and convenience.
Antec New Solution Minuet 350 -UK - desktop slimline - micro ATX
System cabinet
Desktop slimline
Piano black
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
microATX
System Cabinet Features
Desktop to tower convertible, flip-up drive cage, fan speed controller
Power supply 350 Watt
Motherboard Power Connectors
24(20) pin power connector with detachable 4 pin section, 4-pin ATX12V connector
Specification Compliance
ATX12V
31.9 cm x 43.9 cm x 9.4 cm
5.7 kg
3 years warranty
Desktop slimline
Max Mainboard Size
Micro ATX
microATX
ATX12V
Internal Bays Qty
1
Front Accessible Bays Qty
2
Piano black
Fans
Top : 1 x 8 cm - ( 1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 1 (total) / 1 (free) x internal - 3.5"
Expansion Slots
4 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
80 PLUS
Power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
350 Watt
Power Supply Features
Active Power Factor Correction (PFC)
31.9 cm
43.9 cm
9.4 cm
5.7 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellant Quality
Reviewed by Chris Lodge on 18/01/2014
The case arrived in original packaging and un damaged.
The finish is brilliant, black and shinny with a brushed aluminum front panel with 2 small LEDs a on/off switch and 2 USB3 connectors 1 SATA connector. The finish inside is top quality with no sharp edges, a removable internal panel for installing HDD and DVDs makes fitting easier. A note here the HDD must be fitted with the PCB up or it will not fit correctly. The DVD must be fitted first. Easy to fit out but read the instructions carefully first. On my unit there is no mains on switch on the rear panel. The internal fan on low speed is reasonably quiet, as I will use it as a multi-media PC this is nice.
The instructions are adequate.
Scroll to top
