Click to visit BT.com
BT.com
Wishlist
Antec LanBoy Air Blue Modular Gaming Case
Quicklinx: 76C4WS00
Mfr#: 0761345-15004-0
Meet the LanBoy Air. Nearly every part on this case, even the motherboard and PSU mounts, is modular and customizable. Up to 15 exhaust fans create positive air pressure inside the case that blows dust and heat out through panel perforations. Up front, the LanBoy Air's AirMounts HDD mounting system literally suspends drives in mid-air for unsurpassable vibration and noise resistance. Along with its two internal 2.5" SSD bays and a front-panel USB 3.0 port, the LanBoy Air is the last word in high-flexibility PC case design.
Antec LanBoy Air - mid tower - ATX
System cabinet
Mid tower
Black, blue
I/O Connectors
2 x USB 2.0 , 1 x USB 3.0 , 1 x audio line-in , 1 x audio line-out
Installed Fans Qty
5
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Blue LED, AirMount HDD suspension mount system
No power supply
26.9 cm x 53.6 cm x 54.6 cm
8.4 kg
3 years warranty
Mid tower
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
3
Black, blue
Fans
Front : 2 x 120 mm - ( 2 installed) , Rear : 1 x 120 mm - ( 1 installed) , Side : 8 x 120 mm - ( 2 installed) , Internal : 2 x 120 mm - ( 0 installed) , Top : 2 x 120 mm - ( 0 installed)
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x internal - 2.5" , 6 (total) / 6 (free) x internal - 3.5" x 1/3H
Expansion Slots
8 x Expansion Slot
2 x USB 2.0 , 1 x USB 3.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
RoHS
No power supply
26.9 cm
53.6 cm
54.6 cm
8.4 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
Resources
The following resources are available for the Antec LanBoy Air Blue Modular Gaming Case
