Click to visit BT.com
BT.com
Wishlist
Antec ISK 300-150 Mini-ITX Desktop Case
5.0*
Quicklinx: 76C6WS00
Mfr#: 0761345-08175-7
Case Form Factor: Desktop slimline
Motherboard Form Factor: Mini ITX
Power Supply: 150Watt
Colour: Black
£59.66
Mini-ITX is the next "big" thing. And now, Antec introduces the ISK 300-150, designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a stable 150-watt power supply, the ISK 300-150 can handle many of the tasks of a traditional PC, but in half the space. From petite desktop options to silent home theater, Antec's ISK 300-150 is an epic case of mini proportions.
Antec ISK300-150 - desktop slimline - mini ITX
System cabinet
Desktop slimline
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Mini-ITX
System Cabinet Features
Manual fan speed control
Power adapter 150 Watt
AC 120/230 V ( 50/60 Hz )
22.2 cm x 32.8 cm x 9.6 cm
2.5 kg
3 years warranty
Desktop slimline
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Front Accessible Bays Qty
1
Fans
Side : 1 x 8 cm - ( 1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
1 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
150 Watt
22.2 cm
32.8 cm
9.6 cm
2.5 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
Antec ISK 300-150 Mini-ITX Desktop Case Bundle deal on Antec ISK 300-150 Mini-ITX Desktop Case
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£79.19
saving £8.26
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£69.65
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£63.75
saving £0.88
Resources
The following resources are available for the Antec ISK 300-150 Mini-ITX Desktop Case
Customer reviews
Write a review for the Antec ISK 300-150 Mini-ITX Desktop Case here!
Virtually silent, easy to install, low power, solid construction
Reviewed by John Murray. Review Posted 14/11/2011
Antec live up to their reputation with this mini case. It is solidly constructed, easy to fit components in and virtually silent in use. I'm using it with the Intel D525MW motherboard as a low cost, low power LAMP server for use as a test environment for web development and to host a small intranet.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Colour: Black
Brand: Antec
Price Range Inc VAT: 50 - 100
