Click to visit BT.com
BT.com
Wishlist
Antec Formula 7 Thermal Paste
Quicklinx: 7KPBWS00
Mfr#: 0761345-77061-3
Type: Heatsink Grease
Stock Status: Clearance
Express delivery Delivered on Wednesday
Hurry, only 1 left in stock!
£10.27
Antec's Formula 7 thermal compound protects your CPU even when your rig is running on all cylinders. Since little of the CPU's surface actually touches the heat sink, you need a solution that isolates and facilitates the transfer of heat. Formula 7's nano diamond particles minimize the distance between heat-conductive compounds and gladly take on an overclocking environment, optimally performing between -50°C and 250°C. To keep your system cool and your CPU functioning comfortably, pick up Antec's Formula 7 for a diamond-caliber solution.
Antec Formula 7 - thermal paste
Thermal paste
Thermal paste
Thermal Conductivity
8.3 W/mK
-50 °C
250 °C
Antec Formula 7 Thermal Paste Bundle deal on Antec Formula 7 Thermal Paste
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£14.36
saving £1.39
Brand: Antec
Price Range Inc VAT: 0 - 50
