BT.com
Wishlist
Antec Earthwatts 380W ATX 12V 80Plus
Antec Earthwatts 380W ATX 12V...
£54.45
5 in stock
£54.45
Add to wishlist
Delivery
Standard 3-5 working days
Get more power and lower your electric bill with the EarthWatts Green series! One of the most environmentally-friendly power supplies available, the EarthWatts EA-380D Green efficiently delivers 380-watt of reliable and stable power while meeting the bronze level of efficiency from 80 Plus, the most widely recognized independent standard in power supply efficiency. On top of that, this EarthWatts power supply boasts universal input to automatically work on any power grid on the planet, and an 80mm fan to keep cool. Get the power you need, save money and help protect the environment with Antec's EA-380D Green!
Antec EarthWatts EA-380D Green - power supply - 380 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
80 PLUS Certification
80 PLUS Bronze
1.6 kg
Input Voltage
AC 100-240 V
Power Capacity
380 Watt
Output connectors
1 x 6 pin PCI Express power , 5 x 15 pin Serial ATA power , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 24 pin ATX with detachable 4 pin section , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
80 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3
Input Voltage
AC 100-240 V
Input Voltage Margin
± 10%
Frequency Required
47 - 63 Hz ± 10%
Power Capacity
380 Watt
Output Current
+5V 20 A , +3.3V 20 A , +12V1 17 A , +12V2 15 A , -12V 0.8 A , +5VSB 2.5 A
80 PLUS Bronze
Cooling System
80 mm fan
Over current protection, over voltage protection, short-circuit protection
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS
Limited warranty - parts and labour - 3 years
10 °C
50 °C
15 cm
14 cm
8.6 cm
1.6 kg
Scroll to top
