BT.com
Wishlist
Antec C400 Quad Heatpiped Direct Contact CPU Air-Cooler
Antec C400 Quad Heatpiped Direct...
£29.62
13 in stock
£29.62
Add to wishlist
Delivery
Standard 3-5 working days
Combat heat with Antec’s C400 CPU Cooler. Designed for leading Intel and AMD processors, the C400 CPU Cooler supports Intel® Core™ i7 Extreme, and AMD™ Sempron, among others. The 8 mm thick copper coldplate and nickel-plated aluminum fins with four embedded heatpipes achieve maximum heat transference as well as lightweight durability. And with the stealthily quiet blue LED PWM (pulse width modulation) fan, the C400 CPU Cooler is the perfect tool to combat heat when overclocking your processor.
HIGH STATIC PRESSURE LED FAN
Quiet, 120 mm LED PWM fan with 77 CFM of airflow illuminates your rig with blue light
STRAIGHT TOUCH TECHNOLOGY
The 8mm thick copper coldplate and four copper heatpipes with Straight Touch technology quickly transfer heat away from your CPU
UNIQUE HEATSINK DESIGN
Two-tiered fin structure dissipates heat efficiently, while aluminum oxide coating prevents oxidation
BROAD SOCKET COMPATIBILITY
Compatibility with the newest Intel and AMD platforms, and the push-pin mounting system and included gold thermal paste make for a fast, simple installation
Antec C400 - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
800-1900 rpm
Air Flow
77 cfm
Noise Level
20.3 - 34.5 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, 4 copper heatpipes, blue LED
15.5 cm x 12.5 cm x 7.6 cm
830 g
3 years warranty
Processor cooler
Package Content
Thermal paste
15.5 cm
12.5 cm
7.6 cm
830 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
800-1900 rpm
Air Flow
77 cfm
Noise Level
20.3 - 34.5 dBA
Power Connector
4-pin fan connector
Limited warranty - 3 years
Scroll to top
