BT.com
Wishlist
Antec A40 Pro Quad Heatpipe CPU Air-Cooler
Antec A40 Pro Quad Heatpipe CPU...
£18.69
4 in stock
£18.69
Add to wishlist
Delivery
Standard 3-5 working days
Antec A40 PRO. Suitable for: Processor, Type: Cooler, Fan diameter: 9.2 cm. Width: 100 mm, Depth: 75 mm, Height: 136 mm
Antec A40 PRO - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
800-2200 rpm
Air Flow
38 cfm
Noise Level
16 - 23 dBA
Power Connector
4-pin fan connector
4 copper heatpipes, blue LED
10 cm x 13.6 cm x 7.5 cm
570 g
3 years warranty
Processor cooler
Package Content
Thermal paste
10 cm
13.6 cm
7.5 cm
570 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2200 rpm
Air Flow
38 cfm
Noise Level
16 - 23 dBA
Power Connector
4-pin fan connector
Limited warranty - 3 years
£18.69
Save on this ideal PC Build kit!
Save £10.63
£37.86
Scroll to top
