BT.com
Wishlist
Antec A30 Dual Heatpipe CPU Air-Cooler
Antec A30 Dual Heatpipe CPU...
£11.96
21 in stock
£11.96
Add to wishlist
Delivery
Standard 3-5 working days
Defeat heat created by your processor and allow for improved operation with the A30 by Antec. Designed for compatibility with leading desktop processor sockets, the A30 supports Intel Core i7, and AMD Sempron, among others. This budget-friendly CPU cooler features a whisper-quiet 92 mm LED fan and a large, aluminum heat fin structure with two embedded copper heat pipes, allowing your CPU to cool off efficiently.
Antec A30 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1750 rpm
Air Flow
36 cfm
Noise Level
20 dBA
Power Connector
3-pin plug
2 copper heatpipes, blue LED
11.6 cm x 12.25 cm x 8.06 cm
300 g
3 years warranty
Processor cooler
11.6 cm
12.25 cm
8.06 cm
300 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1750 rpm
Air Flow
36 cfm
Noise Level
20 dBA
Power Connector
3-pin plug
Limited warranty - 3 years
Scroll to top
