BT.com
Wishlist
Antec 850W PSU - HCG-850M High Current Gamer Modular APFC 80
Antec 850W PSU - HCG-850M High...
£97.87
£97.87
Add to wishlist
Delivery
Standard Due date unavailable
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty high current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PWS0 BRONZE certification and Active PFC. Circuits hield makes the HCG-850M safe and reliable in any environment with its nine industrial-grade protections. If loads of power, high current engineering and extreme efficiency are what you're after, the HCG M is the PSIJ for you.
Antec High Current Gamer HCG-850M - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.32/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
2.1 kg
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
850 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 8 pin EPS12V , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 17 cm x 8.6 cm
5 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz + 10% / - 10%
Power Capacity
850 Watt
Output Current
+5V - 25 A , +12V1 - 40 A , +12V2 - 40 A , -12V - 0.5 A , +5VSB - 3 A , +3.3V - 25 A
Efficiency
88%
80 PLUS Bronze
Cooling System
135mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, dual 12V rails, short-circuit protection, dual ball bearing cooling fan, surge & inrush protection
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, GOST-R
5 years warranty
Service & Support Details
Limited warranty - 5 years
15 cm
17 cm
8.6 cm
2.1 kg
Antec 850W PSU - HCG-850M High Current Gamer Modular...
£97.87
Save on this ideal PC Build kit!
Save £8.40
£117.09
Scroll to top
