BT.com
Wishlist
Antec 750W True Power 80 Plus Gold 92% Max Efficiency PSU
1 on order, delivery delayed
Delivery
Standard Due date unavailable
Antec's TruePower Classic series sets standards for power supplies. By using a PSU that is 80 PLUS GOLD certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies. TP Classic's PhaseWave design is a server-class LLC design with a synchronous rectification based on a DC-DC topology. Japanese capacitors achieve unprecedented tight voltage regulation & low ripple & noise to maximize your system's performance. Antec's intelligent thermal manager fan control spins the high-quality 12 cm DBB fan optimally to cool your PSU quietly.
Antec TruePower Classic TP-750C - power supply - 750 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.4 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 5 x 4 PIN internal power , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 16.5 cm x 8.6 cm
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+5V - 20 A / 0 A , +3.3V - 20 A / 0 A , +12V1 - 35 A / 0.1 A , +12V2 - 35 A / 0 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0 A
Efficiency
92%
80 PLUS Gold
Cooling System
120 mm fan
Overheat protection, thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, surge & inrush protection, no load operation & brown-out protection, PhaseWave design
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, RoHS, GOST-R, Energy-Related Products (ErP) Lot 6
15 cm
16.5 cm
8.6 cm
2.4 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* exceeds specs
Reviewed by Anonymous on 20/09/2015
Got this PSU as part of upgrade (adding an R9 285 to existing in crossfire). Although non-modular (in this case a benefit because going into a Phanteks enthoo pro m - easy to access if needed, if not cables hidden anyway ;D) cheap as many bronze units and imagine my surprise when I unpacked it and found six - yes six 6/8 pin pci-e connectors! At this price cannot be beaten imo.
Scroll to top
