BT.com
Wishlist
Antec 750W PSU HCG-750M High Current Gamer Modular APFC 80
Antec 750W PSU HCG-750M High...
£104.53
£104.53
Add to wishlist
Delivery
Standard Due date unavailable
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS BRONZE certification and Active PFC. HCG M's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing LED fan complete the package. CircuitShield makes the HCG-750M safe and reliable in any environment with its nine industrial-grade protections.
Antec High Current Gamer HCG-750M - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.32/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
2.1 kg
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 17 cm x 8.6 cm
5 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz + 10% / - 10%
Power Capacity
750 Watt
Output Current
+5V - 25 A , +12V1 - 40 A , +12V2 - 40 A , -12V - 0.5 A , +5VSB - 3 A , +3.3V - 25 A
Efficiency
88%
80 PLUS Bronze
Cooling System
135mm fan
Thermal monitoring , overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, dual 12V rails, short-circuit protection, dual ball bearing cooling fan, surge & inrush protection
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, GOST-R, Energy-Related Products (ErP) Lot 6
5 years warranty
Service & Support Details
Limited warranty - parts and labour - 5 years
15 cm
17 cm
8.6 cm
2.1 kg
Scroll to top
