BT.com
Wishlist
Antec 550W EDGE 80+ Gold PSU
£100.77
Hurry, only 1 left in stock!
£100.77
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Antec's EDGE series is the pinnacle of power supplies. EDGE is fully modular with a revolutionary 18+10-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® GOLD & ErP Lot 6: 2013 certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies. EDGE's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened and also flat (except MBU cable) to become Flat Stealth Wires and are thus nearly invisible in your chassis. 2 High Current Rails and a ~99% +12V output ratio maximize EDGE's capabilities to power the latest CPU's & GPU's. CircuitShield™ makes EDGE safe and reliable in any environment with its 7 industrial-grade protections. Backed by a 5 year warranty and lifetime global 24/7 support, EDGE embodies everything a power supply can accomplish today.
  • 550W Continuous Power - Guaranteed 550W of Continuous Power from Antec
  • 80 PLUS® GOLD certified - Up to 92% efficient, to reduce your electricity bill
  • AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
  • 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
  • 135 mm LED FDB Silence - Whisper-quiet high-quality LED fluid-dynamic bearing fan with long lifetime
  • Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
  • High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
  • 98.2% +12V - Output for maximum CPU & GPU support
  • 28(18+10)-pin MBU socket - For possible future MBU connectors
  • CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP), Over Voltage Protection (OVP), No Load Operation (NLO), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
  • Japanese Heavy-Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
  • Flat Stealth Wires - Flat and darkened wires for minimal visibility in chassis (except MBU cable)
  • ATX12V 2.4 - Engineered according to the newest PSU guideline and compatible with the latest CPU generation
Antec EDGE EDG550 - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
1.8 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section
Cooling System
135mm fan
2 x red Anti-Noise De-Couplers, 2 x black Anti-Noise De-Couplers
15 cm x 17 cm x 8.6 cm
5 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
± 10%
Frequency Required
50 - 60 Hz ± 10%
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V1 - 30 A , +12V2 - 30 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
92%
80 PLUS Gold
MTBF
100,000 hours
Cooling System
135mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, dual 12V rails, short-circuit protection, surge & inrush protection, fan speed control, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan, CircuitShield
TUV, BSMI, CB, CCC, FCC, RoHS, KCC, GOST-R, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
Limited warranty - 5 years
50 °C
15 cm
17 cm
8.6 cm
1.8 kg
£100.77
Save on this ideal PC Build kit!
Save £10.36
£120.32
Scroll to top
