BT.com
Wishlist
Antec 520W HCG-520M High Current Gamer ATX Power Supply
Antec 520W HCG-520M High Current...
£64.75
£64.75
Add to wishlist
Delivery
Standard Due date unavailable
Antec's high current power supply is the perfect PSU combination of power and efficiency. The High Current Gamer features a high-power +12 V rail and special heavy-duty high current connectors and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS bronze certification and active PFC. If loads of power, high current engineering and extreme efficiency are what you're after, the High Current Gamer is the PSU for you.
Antec High Current Gamer HCG-520M - power supply - 520 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.32/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
1.8 kg
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
520 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 5 x 7 pin Serial ATA , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 16 cm x 8.6 cm
3 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz + 10% / - 10%
Power Capacity
520 Watt
Output Current
+5V - 24 A , +3.3V - 24 A , +12V - 40 A , -12V - 0.8 A , +5VSB - 2.5 A
Efficiency
87%
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
135mm fan
Thermal monitoring , over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years
15 cm
16 cm
8.6 cm
1.8 kg
Antec 520W HCG-520M High Current Gamer ATX Power...
£64.75
Save on this ideal PC Build kit!
Save £8.40
£83.97
Scroll to top
