BT.com
Wishlist
Antec 1300W HCP-1300 High Current Pro Platinum Modular APFC 80+ PSU
Antec 1300W HCP-1300 High Current...
£259.93
£259.93
Add to wishlist
Delivery
Standard Due date unavailable
Antec's High Current Pro Platinum series is the pinnacle of power supplies. High Current Pro Platinum is fully modular with a 20+8-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS Platinum and ErP Lot 6: 2013 certified, operating up to 94% efficient, you can reduce your electricity bill by up to 25% when compared to many other power supplies. HCP Platinum's 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pin connectors and even future connectors of 10, 12, 14 or 16-pin.
Antec High Current Pro HCP-1300 Platinum - power supply - 1300 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.32/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
2.2 kg
United Kingdom
Input Voltage
AC 110-240 V
Power Capacity
1300 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 8 pin EPS12V , 10 x 8 pin PCI Express power with detachable 2 pin section , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 9 x 7 pin Serial ATA
Cooling System
135mm fan
15 cm x 19 cm x 8.6 cm
7 years warranty
United Kingdom
Input Voltage
AC 110-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz + 10% / - 10%
Power Capacity
1300 Watt
Output Current
+5V - 25 A / 0 A , +3.3V - 25 A / 0 A , +12V1 - 50 A / 0 A , +12V2 - 50 A / 0 A , +12V3 - 50 A / 0 A , +12V4 - 50 A / 0 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A
Efficiency
94%
80 PLUS Platinum
Cooling System
135mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, 4 x 12V rail, dual ball bearing cooling fan, CrossFireX ready, surge & inrush protection, no load operation & brown-out protection, PhaseWave design, OC Link
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, GOST-R, Energy-Related Products (ErP) Lot 6
Limited warranty - parts and labour - 7 years
50 °C
15 cm
19 cm
8.6 cm
2.2 kg
Antec 1300W HCP-1300 High Current Pro Platinum Modular...
£259.93
Save on this ideal PC Build kit!
Save £8.43
£279.15
Scroll to top
