BT.com
Wishlist
AMD Phenom II X4 965 3.4GHz Black Edition AM3 Socket L2/L3 8MB
Delivery
Standard Due date unavailable
You can take performance over the top with AMD Phenom II processors. Second generation AMD Phenom II processors feature a refined architecture, the award-winning innovation of AMD64 technology with direct connect architecture, and 45nm technology for maximum performance headroom.
You can get the tune performance with the superior headroom of AMD Phenom II processors. Combined with ATI Radeon HD graphics cards, they deliver extreme visual performance and the ability to control and monitor system functions.
Build a total system tuned for performance, beginning with an all-AMD solution including AMD Phenom II processors, AMD chipsets, and ATI Radeon HD graphics with CrossFireX technology for multi-GPU support. Experience the power of gaming beyond high definition.
AMD Black Edition AMD Phenom II X4 965 / 3.4 GHz processor
Processor Type
Number of Cores
Quad-Core
64-bit Computing
Compatible Processor Socket
Socket AM3
Processor Qty
1
Clock Speed
3.4 GHz
Manufacturing Process
45 nm
HyperTransport technology, AMD64 technology, integrated memory controller, Enhanced Virus Protection, AMD Cool'n'Quiet Technology, AMD Virtualization, AMD CoolCore Technology
Compatible Slots
1 x processor - Socket AM3
3 years warranty
Type / Form Factor
Number of Cores
Quad-Core
Cache Memory Details
L2 - 4 x 512 KB , L3 - 6 MB
64-bit Computing
Processor Qty
1
Clock Speed
3.4 GHz
Socket AM3
45 nm
Thermal Design Power
125 W
Thermal Specification
62 °C
Architecture Features
Cache Memory
Installed Size
6 MB
Compatible Slots
Cooler (fansink)
Package Type
AMD Processor in a Box (PIB)
Limited warranty - 3 years
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* General and overclocking
Reviewed by Anonymous on 11/12/2009
Great cpu, overclocked to 3.8 with a minor voltage increase and heat. Using a standard full tower style case, with only the usual 3 fans, 1 front, 1 side and 1 back.
5* Powerful, Cheap, but Loud
Reviewed by Dasos on 09/01/2011
This processor is an absolute power house.
I am really impressed with it, and at this price it's unmatched by the competition.
The only issue is the stock cooler, which for me is just way too loud, running at over 6k RPM in load with the CPU hitting about 65°C under extreme stress.. It sounds like the PC is ready to take off into the sky.
Other than that though, it really is nice, and I plan on getting an aftermarket cooler asap
5* Great CPU
Reviewed by Andrew on 31/12/2011
I used this in my first build in conjunction with a M5A78L-M/USB3 motherboard. It runs very cool reporting up to 35C when idle and up to 52C in load (18 Hours of Prime95 blend test). I have heard that the core temperatures can be up to 10C out, but that is still good temperatures for 3.615GHz @ 1.32V on a stock cooler. I was stuck between Intel or AMD, a Dual core i3 or a Quad core Phenom II to fit my £350 budget. I originally chose a Phenom II 955, but went out of stock a day before i was about to order it. Overall i think this is a very good CPU, it handles everything i through at it. Its not a i5-2500k, but at nearly half the price (At time of writing) its worth it.
5* Awesome - powerful and cool
Reviewed by Mark P on 15/08/2010
Great CPU - was deliberating between the new Intel Corei-series or these; eventually picked this due to cost, and I'm not disappointed.
It's more than powerful to handle everything I've thrown at it so far (a Linux box running Mythbuntu, with 4 physical tuner cards - 16 virtual tuners - so potentially lots of stuff happening!) without even breaking a sweat.
I bought a 3rd party cooler - the Akasa 4-heatpipe nickel-plated one (QL: 69RZ09) which fits in the Antec300 case perfectly and keeps the CPU at under 40C... remarkable, considering that the much less powerful processor in my Acer Revo 3610 runs at nearly 60C!
5* Amazingly Fast CPU!
Reviewed by James Sawyers on 12/05/2012
I bought this CPU because i was on a tight budget of £500 and i am glad i did! This CPU plays any game you throw at it fine, it is such a step up from my old Intel Pentium D, it is supposed to be a great overclocker, but i don't believe in overclocking. My system runs Windows 7 Professional x64 and i can run FSX and GTA IV on max graphics with no lag at all. I would definitely recommend this to anyone who can't afford the higher end processors such as the Core i7 etc.
5* Extremely Impressive
Reviewed by Matt on 03/08/2010
Just bought this from BT and it is extremely impressive. Not only is this a fast CPU that puts my old Intel CPU in the shade, but BT couldn’t have given any better service, with my order arriving at the earliest opportunity, even without next day delivery. Highly recommended to all.
5* Awesome!
Reviewed by Yewzi on 21/01/2010
I've recently upgraded to this processor from an old intel p4 2.4 system and boy can i tell a difference! Very impressed :)
5* monster fast
Reviewed by 1366_haylett on 11/02/2011
fitted this with a cooler master hyper 212 and got 29c at idle and 45c at full power. very quick and cool running for such a big processor. 7.4 windows experiance score
5* greate cpu BAD stock cooler
Reviewed by Jordan on 08/08/2012
But please get an after market cooler as the stock AMD one cant keep it cool at stock voltage. Had to drop it from 1.475 to 1.300 to keep it below 62. And yes i have a well ventilated case fractal arc midi. As for the CPU well its just perfect for me its more than enough for any games today and programs.
5* Great CPU, noisy cooler
Reviewed by Antony on 12/05/2010
Excellent CPU, handles everything you throw at it without breaking a sweat. Heatsink/fan included is noisy consider buying a better cooler.
Scroll to top
