BT.com
Wishlist
Allied Telesis Fibre Media Convertor
Allied Telesis Fibre Media...
£94.99
£94.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Allied Telesis' range of Fast Ethernet Media converters provides a complete series of conversion devices, allowing users to extend the size of UTP and multi-mode fiber networks with the use of single-mode fiber cabling. Supporting SC-connected single-mode fiber, these converters can be used to extend networks up to a distance of 2km.
All these media converters feature an internal MDI/MDIX switch, allowing the converter to be connected to PC, hub or switch with a simple UTP cable. The media converters also allow the installer to test the integrity of fiber connection, by forcing the converters to communicate over the fiber cable. This Link Test feature allows installers to check for cable faults without the need for expensive fiber optic test equipment.
Allied Telesis AT MC102XL - fibre media converter - Fast Ethernet
Fibre media converter - SC multi-mode / RJ-45
External
Cabling Type
100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
Fast Ethernet
Max Transfer Distance
2 km
10.5 cm x 9.5 cm x 2.5 cm
294 g
Environmental Standards
ENERGY STAR Qualified
5 years warranty
External
Wired
Cabling Type
Fast Ethernet
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Link activity, port duplex mode, power, link OK, test mode
Auto-negotiation, MissingLink, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
IEEE 802.1Q
1 x Ethernet 100Base-FX - SC multi-mode x 2 , 1 x Ethernet 100Base-TX - RJ-45
FCC Class B certified, CSA, UL, TUV, cUL, RoHS
External power adapter
10.5 cm
9.5 cm
2.5 cm
294 g
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 - 95%
Scroll to top
