BT.com
Wishlist
Allied Telesis AT MCR12 - media converter
Allied Telesis AT MCR12 - media...
£376.68
£376.68
Add to wishlist
Delivery
Standard Due date unavailable
The AT-MCR12 media converter rack-mount chassis is just what network managers need to clean up their wiring closets. It supports up to 12 Allied Telesis' media or 10/100 speed converters in any combination of 10Mbps or 100Mbps. The AT-MCR12 consolidates power connections by providing an internal, 80-watt universal power supply. An optional, hot-swappable second power supply can be added to ensure against downtime. The chassis installs easily into a standard 19" network rack, and features LED status lights on the front panel to help in network troubleshooting.
Allied Telesis simplemente conecta el mundo IP con soluciones para redes muy confiables y de bajo costo. La compañía ha logrado y mantenido su liderazgo en el mercado en los sectores de empresas grandes, medianas y pequeñas, desarrollando un diverso portafolio de componentes que construyen redes flexibles, eficientes, de costo efectivo y confiables.
Media converter
External - rack-mountable
United Kingdom
AC 200/240 V
44.4 cm x 21.7 cm x 13.2 cm
4.54 kg
Media converter
Rack-mountable - external
Installed Modules Qty (Max)
0 ( 12 )
United Kingdom
Wired
Status Indicators
Expansion Slots
12 (total) / 12 (free) x Expansion Slot
Rack Mounting Kit
Included
FCC Class A certified, CSA, TUV
Installed Qty
1
Max Supported Qty
2
AC 200/240 V ( 50/60 Hz )
UL
44.4 cm
21.7 cm
13.2 cm
4.54 kg
Limited warranty - lifetime
5 - 80%
Scroll to top
