BT.com
Wishlist
Allied Telesis Allied Telesyn 100Mbps Fast Ethernet PCI-Express Fiber Adapter Card
Allied Telesis Allied Telesyn...
£140.22
More than 50 in stock
£140.22
Add to wishlist
Delivery
Standard 1-3 working days
AT-2711FX 1x PCI-Express design gives you the maxim possible bandwidth and bus efficiency, Hot Swappable capability and Low Power Consumption.
The priority queuing and virtual LAN features offered by AT-2711FX can help users set up the network based on their own needs. The comprehensive diagnostics and configuration software suite provides system administrators and engineers with a profound tool to analyze the network adapter and check specific data.
AT-2711FX Fast Ethernet Fiber Adapter comes with a variety of reliability features. They aim at maintaining a connection as long as possible. This is reached by link aggregation, heterogeneous mixed-speed failover and hot swap.
Allied Telesis AT-2711FX/ST - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
10/100 Ethernet
12.1 cm x 6.9 cm
50 g
Cabling Type
Ethernet 100Base-FX
100Mb LAN
Max Transfer Distance
2 km
Data Transfer Rate
100 Mbps
1 x BCM5752 - Broadcom
RAM
72 KB
IEEE 802.2, IEEE 802.3u, IEEE 802.1p, IEEE 802.1x, IEEE 802.3ac
Novell NetWare 6.x, Linux 2.4, Microsoft Windows Server 2003, Linux 2.6, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
Network adapter
Plug-in card
PCI Express x1
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet 100Base-FX
100Mb LAN
Data Transfer Rate
100 Mbps
2 km
Remote Management Protocol
SNMP
Status Indicators
Link activity, link OK
Flow control, ACPI support, wake on LAN (WOL), IPv6 support, half duplex mode, full duplex mode, Quality of Service (QoS), PXE support
Processor / Memory
RAM
72 KB
1 x 100Base-FX - ST multi-mode x 2
Compatible Slots
1 x PCI Express x1
Low-profile bracket, full-height bracket
FCC Class B certified, UL, TUV, VCCI, C-Tick, EN55024, EN55022 Class B, RoHS
TAA Compliant
12.1 cm
6.9 cm
50 g
Limited warranty - lifetime
50 °C
5 - 90% (non-condensing)
Scroll to top
