BT.com
Wishlist
Allied Telesis Allied Telesyn 1000SX Desktop PCI Network Adapter
Allied Telesis Allied Telesyn...
£151.06
£151.06
Add to wishlist
Delivery
Standard Due date unavailable
Allied Telesis' AT-2916SX is a high reliable 32-bit PCI Gigabit Fiber Adapter card. It helps to boost your Fast Ethernet desktop throughput ten times to 1000Mbps. With the 1000Base-SX fiber-optic connection, data transmission is both secure and faster.
In order to reduce CPU usage, Allied Telesis' AT-2916SX uses the adaptive interrupts and ultra-deep 96-KB packet buffer. Coupled with link aggregation and load balancing, AT-2916SX achieves the best performance of its class for server connectivity.
Allied Telesis AT-2916SX/SC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 2.2
Ports
1000Base-SX
1.3 cm x 17.8 cm x 5.1 cm
85 g
Cabling Type
Ethernet 1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1ab (LLDP)
Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 2000 / XP, Linux 2.4.x
Microsoft Certification
Works with Windows Vista
Network adapter
Plug-in card
PCI
PCI 2.2
Ports
1000Base-SX
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Status Indicators
Link OK, link/activity
Full duplex capability, ACPI support, auto-negotiation, remote reboot, VLAN support, wake on LAN (WOL)
1 x 1000Base-SX - SC multi-mode - x 2
Compatible Slots
1 x PCI
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
ACPI, FCC Class B certified, UL, VCCI, RoHS, EN 55022
Software Included
Drivers & Utilities
1.3 cm
17.8 cm
5.1 cm
85 g
10 °C
55 °C
10 - 95%
Scroll to top
