BT.com
Wishlist
Allied Telesis Allied Telesyn 1000SX Desktop Fibre PCI-X NIC
Allied Telesis Allied Telesyn...
£162.20
Hurry, only 1 left in stock!
£162.20
Add to wishlist
Delivery
Standard 1-3 working days
Gigabit connectivity through fiber to server and desktop.
Allied Telesis AT-2931SX/SC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI hot-plug
PCI Specification Revision
PCI 2.2
Ports
1000Base-SX
1.3 cm x 17.8 cm x 5.1 cm
85 g
Cabling Type
Ethernet 1000Base-SX
GigE
Max Transfer Distance
500 m
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1ad
Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 2000 / XP, Linux 2.4.x
Microsoft Certification
Works with Windows Vista
Network adapter
Plug-in card
PCI hot-plug
PCI 2.2
Ports
1000Base-SX
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
500 m
TCP/IP, UDP/IP
Status Indicators
Link/activity
Flow control, auto-negotiation, load balancing, VLAN support, full duplex mode
1 x 1000Base-SX - SC multi-mode x 2
Compatible Slots
1 x PCI hot-plug
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL, VCCI, EN55022 Class B, FCC
1.3 cm
17.8 cm
5.1 cm
85 g
10 °C
55 °C
10 - 95%
Scroll to top
