BT.com
Wishlist
Akasa XP3400+ Sempron Cooler
Akasa XP3400+ Sempron Cooler...
£9.60
£9.60
Add to wishlist
Delivery
Standard Due date unavailable
Designed for Socket A 462
AMD Athlon XP 3400+ and all Socket A Sempron.
AK-786 is a low-noise, high performance value cooler. AK-450 thermal compound is pre-applied. New production technology has produced this high performance value cooler.
Features:
  • Lo-noise high performance cooler.
  • Hi-performance thermal compound is pre-applied.
Akasa AK 786 - processor cooler
Processor cooler
Compatibility
Socket A
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Ball bearing
Rotation Speed
3200 rpm
Air Flow
20 cfm
Noise Level
28.5 dBA
Processor cooler
Heatsink & Fan
Compatible With
Socket A
Processor Compatibility
Athlon XP - up to 3400+ , Sempron
Heatsink Dimensions
80 mm x 70 mm x 43 mm
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Ball bearing
Rotation Speed
3200 rpm
Air Flow
20 cfm
Noise Level
28.5 dBA
£9.60
Save on this ideal PC Build kit!
Save £16.94
£34.98
Scroll to top
