BT.com
Wishlist
Akasa Venom Pico Performance Multi-Platform CPU Cooler
Akasa Venom Pico Performance...
£18.98
£18.98
Add to wishlist
Delivery
Standard Due date unavailable
Venom Pico Performance is a unique cooler combining high performance with great value and striking looks.
The highly effective 92mm fan in killer Viper yellow delivers vast amounts of airflow for top notch cooling. The PWM function ensures quiet operation during normal system use and performance cooling under load. Two copper heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium fins. Anti-vibration rubber fan mounting pins help to eliminate a lot of fan noise.
New design akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
  • Low noise 9.2cm PWM fan in killer Viper yellow
  • Intel push pin for reliable and easy installation
  • Two copper heatpipes with direct CPU contact
Akasa Venom Pico AK-CC4009EP01 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket FM1
Heatsink Material
Aluminium and copper
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
57.9 cfm
Noise Level
34.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9.4 cm x 7.6 cm x 138.5 cm
364 g
Processor cooler
9.4 cm
7.6 cm
138.5 cm
364 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Quad , Core 2 Duo , Core i3 , Core i5 , Athlon , Athlon II , Phenom , Phenom II
Heatsink Material
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
57.9 cfm
Air Pressure
5.59 mm
Noise Level
34.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
MTBF
40,000 hour(s)
£18.98
Save on this ideal PC Build kit!
Save £10.76
£38.15
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Whisper Quiet
Reviewed by Gavin on 15/03/2014
Can hardly hear this running. Excellent cooler.
Scroll to top
