BT.com
Wishlist
Akasa Venom Medusa, Multi platform, 8 Hi capacity HP Cooler with 1
Akasa Venom Medusa, Multi platform,...
£64.38
£64.38
Add to wishlist
Delivery
Standard Due date unavailable
  • Socket type - Intel LGA775, LGA1155, LGA1156, LGA1366 & LGA2011, AMD Socket AM2, AM2+, AM3, AM3+ & FM1.
  • Heatsink material - 8 heatpipes, copper base, aluminium fins.
Akasa Venom Medusa AK-CC4010HP01 - processor cooler
Processor cooler
Package Content
Thermal paste, fan resistor cable, PWM fan adapter cable
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1
Heatsink Material
Aluminum with nickel plated copper base
Fans Qty
Dual
Fan Diameter
120 mm/145 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1600/1900 rpm
Air Flow
83.6/109.5 cfm
Noise Level
6.9 - 28.9/7 - 21.7 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, S-FLOW blades, dual Viper fans
14.4 cm 16.3 cm
1.3 kg
Noise reduction
Processor cooler
Package Content
14.4 cm
16.3 cm
1.3 kg
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
163 mm x 144 mm x 129.5 mm
Fans Qty
2
Fan Diameter
120 mm/145 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1600/1900 rpm
Air Flow
83.6/109.5 cfm
Air Pressure
2.91/2.98 mm
Noise Level
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Noise reduction
Akasa Venom Medusa, Multi platform, 8 Hi capacity HP...
£64.38
Save on this ideal PC Build kit!
Save £8.29
£83.55
Scroll to top
