BT.com
Wishlist
Akasa Venom A20 Dual Radiator Liquid CPU Cooler
Akasa Venom A20 Dual Radiator...
£71.58
£71.58
Add to wishlist
Delivery
Standard Due date unavailable
Features:
  • All-in-one liquid cooler design for easy installation
  • High precision CNC Copper base for high efficiency heat transfer
  • New low noise 4-pole pump reduces vibration
  • Durable large diameter tubes provide smooth and quiet flow
  • Reinforced four layer tube
  • Low noise Viper fan with S-FLOW blades
  • Award winning S-FLOW fans provides 30% more airflow
  • Integrated white LED indicator
  • Oxygen-free copper base
  • High Density FPI (fins per inch) radiator for rapid heat transfer
  • 2 Year Warranty
Akasa Venom A20 AK-LC4002HS01 - liquid cooling system radiator with fan
Liquid cooling system radiator with fan
Package Content
Power cable, thermal paste, screws, backplane, spacers, back plate spacer, Clip for AMD, 1x fan cable splitter, Intel clip, thermal compound, 2 x 120mm fans, spring nuts, insulating protective tape
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA1151 Socket, Socket FM3+
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600-1900 rpm
Air Flow
83.63 cfm
Noise Level
6.9 - 28.9 dBA
Rated Voltage
12 V
White LEDs, S-FLOW blades, dual Viper fans, reinforced four layer tube, oxygen-free copper base, U-shaped micro fin flow path design
Package Content
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Heatsink Dimensions
272 mm x 120 mm x 27 mm
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600-1900 rpm
Air Flow
83.63 cfm
Air Pressure
2.98 mm
Noise Level
6.9 - 28.9 dBA
Rated Voltage
12 V
Mounting Kit
Included
£71.58
Save on this ideal PC Build kit!
Save £8.40
£90.80
Scroll to top
