BT.com
Wishlist
Akasa USB 3.0 Multi Card Reader SD4.0 Suppported
Delivery
Standard Due date unavailable
  • Stylish brushed aluminium finish
  • Supports SDHC / SDXC and new UHS-II standard
  • Four card-slots are active at the same time, allowing cross format data transfer
  • Windows XP / Vista / 7 / 8.X / 10 (supports USB 3.0) Mac OS X 10.3 or higher (supports USB 2.0)
Akasa card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Host Interface
USB 3.0
Brushed aluminum
Host Interface
USB 3.0
Brushed aluminum
5.6 cm
8 cm
1.8 cm
Required Ports
1 x 10 pin Micro-USB Type B
Apple MacOS X 10.3 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
USB 3.0 cable
Plug and Play
Scroll to top
