BT.com
Wishlist
Akasa USB 3.0 ExpressCard (2 x USB 3.0 Ports)
Akasa USB 3.0 ExpressCard (2 x USB...
£14.82
£14.82
Add to wishlist
Delivery
Standard Due date unavailable
The AK-EXCU3-01 express card adds two Super Speed USB 3.0 ports to the notebook PC. The USB 3.0 interface enables data transfer at 5 gigabits per second which is up to 10 times faster than USB 2.0! Super Speed interface can save you a lot of valuable time as you no longer needs to wait so long to complete data transfer especially those large files like HD movies or system backups. Furthermore USB 3.0 ports remain fully backwardly compatible with USB 2.0 devices providing you with excellent compatibility. The built in jack power connector enables 5V power adapter connection to ensure enough power delivery for all types of power-hungry USB devices.
Akasa AK-EXCU3-01 - USB adapter
USB adapter
Plug-in module
Interface (Bus) Type
ExpressCard/54
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
USB 3.0 x 2
4 cm x 11.6 cm x 1.4 cm
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Vista / XP / 7
USB adapter
Plug-in module
ExpressCard/54
Bus Voltage
Ports
USB 3.0 x 2
Wired
Data Transfer Rate
5 Gbps
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x ExpressCard/54
Software Included
Drivers & Utilities
4 cm
11.6 cm
1.4 cm
£14.82
Save on this ideal PC Build kit!
Save £8.29
£33.99
Scroll to top
