BT.com
Wishlist
Akasa Slimfan AK-FN078 120mm Case fan - Designed for HTPC/Slim Systems
Akasa Slimfan AK-FN078 120mm Case...
£7.68
£7.68
Add to wishlist
Delivery
Standard Due date unavailable
  • PWM function.
  • Precision balanced low air impedance fan blades.
  • Suitable for HTPC and slim system.
Akasa Slimfan AK-FN078 - case fan
Case fan
Fan Diameter
120 mm
Fan Height
15 mm
Fan Bearing
Entering bearing
Air Flow
54.6 cfm
Noise Level
30.32 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
12 cm x 12 cm x 1.08 cm
Case fan
12 cm
12 cm
1.08 cm
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
15 mm
Fan Bearing
Entering bearing
Air Flow
54.6 cfm
Air Pressure
1.36 mm
Noise Level
30.32 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Akasa Slimfan AK-FN078 120mm Case fan - Designed for...
£7.68
Save on this ideal PC Build kit!
Save £16.94
£33.06
Scroll to top
