BT.com
Wishlist
Akasa Slimfan AK-FN076 80mm Case fan - Designed for HTPC/Slim Systems
Akasa Slimfan AK-FN076 80mm Case...
£6.78
£6.78
Add to wishlist
Delivery
Standard Due date unavailable
  • PWM function.
  • Precision balanced low air impedance fan blades.
  • Suitable for HTPC and slim system.
Akasa Slimfan AK-FN076 - case fan
Case fan
Fan Diameter
80 mm
Fan Height
10.8 mm
Fan Bearing
Entering bearing
Air Flow
26.5 cfm
Noise Level
25.1 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
8 cm x 8 cm x 1.08 cm
Case fan
8 cm
8 cm
1.08 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
10.8 mm
Fan Bearing
Entering bearing
Air Flow
26.5 cfm
Air Pressure
1.81 mm
Noise Level
25.1 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Akasa Slimfan AK-FN076 80mm Case fan - Designed for...
£6.78
Save on this ideal PC Build kit!
Save £8.40
£26.00
Scroll to top
