BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Akasa SATA 3.0 6Gb/s 1m Blue UV Rounded Cable
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Blue-UV 6Gb/s SATA3 cable
New Serial ATA revision 3.0 cables designed for ultra fast data transfer up to 6Gb/s. Third generation of SATA technology cables are compliant with new NCQ streaming for high quality audio and video. Straight to right angle connectors compatible with stacked SATA motherboard connectors. SATA 6Gb/s cables are backwards compatible with SATA and SATA II devices. Round shape aids airflow and blue-UV colour adds style.
  • SATA revision 3.0 supporting 1.5 / 3.0 and 6.0 Gb/s data transfer
  • Straight 7-pin to right angle 7-pin with securing latch
  • New NCQ streaming compliant for high quality audio and video
  • Rounded cable aids airflow and blue-UV colour adds style
Spec
  • Application SATA data connection
  • Design for SATA hard drives and optical devices
  • Length 100cm
  • Colour Blue-UV
  • Motherboard connector Straight (7pin)
  • HDD connector Right angle with latch (7pin)
  • Supported connections SATA 1.5 / 3.0 / 6.0 Gb/s
Scroll to top
