BT.com
Wishlist
Akasa NewtonH Fanless Solid Aluminium Case for 4th Generation Intel NUC boards
Akasa NewtonH Fanless Solid...
£65.92
£65.92
Add to wishlist
Delivery
Standard Due date unavailable
Aluminium fanless CPU cooling design
Ideal for business, education and embedded environments
Form factor: UCFF 4" X 4"
Support IR remote function
Suitable for VESA mounting
Antenna fitting holes
Kensington lock
Compatible with the following Intel® NUC motherboard
  D54250WYB
  D34010WYB
Suitable for
VESA mounting
USB 3.0 port &
Kensington lock
Totally silent
all aluminium body for
quick heat dissipation
aluminium heatsink for
heat transfer
CPU
Akasa Newton H - ultra small form factor - UCFF
System cabinet
Ultra small form factor
I/O Connectors
2 x USB 3.0 , 1 x audio line-in , 1 x audio line-out
System Cabinet Features
Made of aluminium, VESA mounting interface, Kensington lock support, aerial fitting holes
15 cm x 17 cm x 4.7 cm
Max Mainboard Size
UCFF
Thermal paste, rubber feet, securing screws, VESA mounting screws
15 cm
17 cm
4.7 cm
Akasa NewtonH Fanless Solid Aluminium Case for 4th...
£65.92
Save on this ideal PC Build kit!
Save £10.63
£85.09
Scroll to top
